You should have a secondary pump for the UFH and if using a combi you need to check MI's that you can have a secondary pump. So you're retro fitting of mani and pump idea if it doesn't work properly (which it won't) will go out the window if you can't have one on your particular boiler. Just do it properly INHO or not at all.
Most of the underfloor systems i have fitted have required the pipework to be left at 6bar when screeded over, then dependant on what the screed is made of the temp needs to be controlled and slowly increased as to not shock the screed compound and cause cracking in the floor. I can only see one outcome to this situation.
Most underfloor manufactures will help with design and even produce drawings for you free of charge if you are buying there kit, when i have been unsure in the past i have requested them onsite for advise and they are happy to help.
Let us know how you get on?
It's only hot water. It's only gas....
Hi Howsie For your reassurance, I am not going to fit the boiler myself, I found a nice chap from Watchdog!
mick it takes some going to annoy the chaps on here,
its not like other forums as i have said in the past. Take a hint and call in some underfloor guys, of which I am not.
I think all your trying to do mate is take the micky, listen to people that know, think the replys from the lads have been very ploite, dont push it anymore.
complete knob 20mm flat bit required,sorry off topic thought it was the carpentry forum,heads gone again
