View the thread, titled "Advice required on fitting radiator into conservatory" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dr Strangeglove
I would like to fit a radiator into my conservatory. I currently have a wall mounted boiler that is situated against the wall the radiator would be on. As we have a fitted kitchen I want to make sure I get the right kit before I start and I want to make sure the layout, fitting and sizes will be suitable. The boiler is a Myson, Orion 60B (which according to the manual is either 50 or 60,000 btu/h). So this is what I have:
Conservatory = 5m wide x 2.3m deep x 2.2 high.
I have a wall space to fit the radiator which is 3m x 1.1m
My boiler is fitted toward the end of this wall space on a wall at 90 degrees (in the opposite room obviously).
The distance from the top of the boiler (which I presume is where the hot water outlet is!) to the bottom of the wall is 2.2m.
The route I will need to take is Tee from the main pipe, 90 degrees down, 90 degrees along the wall, 90 degrees through the wall, and then to the radiator. (then a similar return route).
I would like to have a thermostat of some kind in the conservatory but in all honesty I think the problem will be that I need more heat not less!
I need to know:
What size radiator
What type of heat control?
What type of pipe and fittings – I was thinking 15mm copper as I don’t want to restrict flow.
Do I need any bleeds or drains?
What do I need to do to avoid airlocks etc?
How should I break into the existing system, how do I drain it and how do I refill it. The boiler seems to have 4 pipes in sets of two each pair having 1 x 22mm and one larger. The pipe to the pump (which is just above the boiler) is one of the 22mm ones.
Sorry to go on but I thought you were better with more info than less.
I understand you wanting to do this yourself but it will work out cheaper if you get a plumber in to do the job, If you make a mistake it will be more expensive to put it right.
for the rad size you will need to know what each wall is made from as well as the sizes and the amount of glass.
You may want to look at underfloor heating (electric under tile heating).
Further to uug197h. I agree that on some occaisions its cheaper to get someone in. (The plasterer has just gone , got done in 3 days what I have been putting off for a year Mrs lee is now walking around with that smug told you so look)
Its always hard to give advice blind,
From your description there are some other things to consider,
Heat control . Thermostat or just TRVs, with a stat we are now talking possible zone control and lots of more bits.
Will the boiler take another rad and still remain efficient.
I would go for the quote option and let a plumber do all the research for you. Once you got that then you look at all the options.
Good luck
Thanks for the replies.
Firstly it will only cost me more if I do the work incorrectly. The reason for asking on this forum is to make sure I am capable of doing the work and ensuring that I am aware of the pitfalls and possible problems. A good plumber will do the work quickly, neatly and to a good quality. But as with all tradesmen, you don’t know how good a job they will do until it is done.
I fitted my own house alarm. It was hard work and took me two days to do what an installer would take ½? day. The difference is all my wiring is hidden behind coving as I was prepared to do the time consuming awkward items that they could not afford to do in their time plan. My friend had an alarm fitted shortly after I did mine and the mess they left him with was awful. His was a better spec than mine but his cost £3k compared to my £200, but mine was by far the neater job.
I would not want to have a separate thermostat control as I think this is taking it too far for what I need. I really wanted to know what things to avoid in relation to air traps, pipe sizes, tips on breaking into the pipe (draining etc) and what size radiator.
I can solder copper pipe etc, and I can work out the pipe lengths required etc. I am a sheet metal worker by trade (though I have been on the design side for a while now) and I have soldered using iron and torch plenty of times. The one thing I find from forums is experience which is something you can not get from a book. If you gents have any tips or warning then I would welcome them. I can assure you if I think I am not capable I will not attempt to do the work.
Thanks for your help so far.
Regards
Mick
I cant really help without seeing what your describing, however the best thing to do if your planning on adding another radiator to the system would be to tee off the current flow and return loop pipework (under the floor boards) It all depends on what type of central heating system you have. Teeing off the top off the boiler is a definate no-no. Its best left to a plumber/heating engineer. You dont want to end up with a rad that doesnt get hot, or a heating system under negative pressure or pumping over etc
Reply to the thread, titled "Advice required on fitting radiator into conservatory" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Dr Strangeglove,
bbb,
