We have a job to replace 3 Andrew's gas fired cylinders in a commercial premises because the existing ones are after only 7 years. Andrew's technical have said its probably due to limescale but have advised against fitting a water softener.
Can anyone advise what is best to a system like this instead of a softener? Maybe a water conditioner. What is best conditioner to fit ?
Each cylinder will be 380 litres.
The cylinders are fed via very large storage tanks and a boost set. See attached
