Aug 9, 2009
149
Maldon
Heating Engineer (Has GSR)
We have a job to replace 3 Andrew's gas fired cylinders in a commercial premises because the existing ones are after only 7 years. Andrew's technical have said its probably due to limescale but have advised against fitting a water softener.
Can anyone advise what is best to a system like this instead of a softener? Maybe a water conditioner. What is best conditioner to fit ?
Each cylinder will be 380 litres.
The cylinders are fed via very large storage tanks and a boost set. See attached
The reason for not wanting a softener is because of water flow issues they can’t pass enough water through
Nothing just good maintenance and replacement of anode rods
Yes I thought replacement but below is the reply from technical when I asked the question
"The anodes are non-sacrificial and therefore do not require any maintenance or replacement. For this reason, the service clearance required above the water heater can be reduced quite significantly. Correx anodes require a permanent power supply, this is all pre-wired and the anode system can be located at the top of the heater, beneath the top cover"
