T
TomLane
The latter , honest guv
I believe you........ Honestly....... Thousands wouldn't though!
Sent from my iPad using Tapatalk HD
Sounds to me the small claims route is your best option, but first he has to give you the opportunity to rectify any faults / shoddy work etc.
I would suggest you write to him asking to detail in writing what he considers to be a problem, then work through each item one by one. It should be easy to prove if the rads are correctly sized or not, but the other stuff ie positioning of rads etc not so easy if you have nothing in writing.
If a magistrate sees you've made every effort to make ammends and be reasonable to the guy I'd say you stand a good chance of getting your money (plus costs).
And if he is seen to be unreasonable - it'll do him no favours at all.
Hope it all works out for you
Take his gas meter out, throw it in the garden, turn his water off and smash the handle of with a hammer then **** in his letterbox.
You won't get your money but you'll feel better.
Use the search function on here and putt in croppie
He does look the type you dont want to upset dont he ...jesus just the thought of him chasin me with a pair of 24's would have me cackin me pants lol
I've done the post mix one hahahahaSuperglue a disk into the inlet and outlet of the gas meter. Then drill a small hole into the base of his soil stack and fill it with expanding foam. Then turn off the stop tap at the street and dump a load of postcrete in.
Got to be more humane than smashing him in the chops and taking a stillson to his collar bones.
