L
Lincsplumber
Evening gents,
I need some advice please! I'm half way through a detached house renovation, the customers initially required a system boiler( he requested and bought), water softened supply (to everything,bar cold supplies @ kitchen sink/ basins) unvented h/w and the house zoning into upstairs/ downstairs/ towel rail/ hot water circuits. I have lovingly installed all the required requests, but only used the two pipe method from the boiler and not the four pipe to include the hot water circuit. I have used 4 x honeywell zone valves to control the system, incorporating 1x hard wired honeywell programmable stat and 1x wireless stat to control the heating side, twin channel clock to control towel circuit and hot water.
Everything is up and running, using a HC1B constant temperature controller........well sort of!! here's the headache causing issues i'm having.
The vitodens 200 initially coming up with an 18 fault ( apparently a weather compensater fault) It hasn't got one, so assuming need to switch off that in the coding???
I can't seem to adjust the boiler temperature output, again probably requires changing in the coding?
In a nutshell the boiler needs setting up for the heating system..........How?
Please help chaps. i'm at a loss. Why do our German friends feel the need to make things so frikkin complicated, all i need is the thing to give me controllable heat using english type ancillaries.
Hi pal, I love the 200 but , you won't want to read this, if you use all the Viessmann Gear especially the 4 pipe system, they are so simple even I can do it.
however that's a thought for next time !
Do you know any of the Viessmann reps because I am sure they will put you in touch with one off there guys.
I am over in West Yorkshire, the two blokes who cover our area are sound, but I have no idea how far their area covers.
Thanks Townfan for the swift response! i would've normally used the four pipes, but i had to utilise the old 28mm circ's as i couldn't get another two pipes across underneath a very expensive tiled bathroom. I'm sure it is very simple to program once i've been educated, but for years i've been a "Vaillant" man, but i've lost all respect for their unreliable/ over expensive products, so now fit Viessmann as a top spec item.
I may be wrong on this, but I think you have to use the Viessmann boiler control that fastens to the boiler, either the constant temp one or the weather comp.
Again thanks, I forgot to add .......it has the hc1b constant temperature controller!
I've edited my initial post.
