anyone have experience with conex push fit
View the thread, titled "anyone have experience with conex push fit" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
G
GBZ
I am interested in hearing any views on conex push fittings, both for water and gas.
I have a piece of work coming up and will need to keep 'hot' work to a minimum.
Views much appreciated.
Keith
You can't use Conex on Gas pipe work. Infact you can't use any pushfit on gas as they all seal with a rubber O ring. Which would quickly melt in case of a fire and thus you would have a major gas leak very quickly. This is fairly common knowledge. No offense meant.
As to my opinion on them for water. Personally I think they're great...Grant supply them as standard connections for some of their boilers. Which is quite an accolade when you think about it.
Actually, I understand that Conex make a fitting called >B< press which can be used with gas.
Thanks for the other info though.
conex b press fittings are not push fit. I have used a simular type of fittings before and they work very well, the ones i used requred the hiring of an battery powered pressing machine and diffrent size jaws. i think it was made by AEG and used the same batteries as there battery drills.
whats the cost diffrence between them and normal end feed?
Reply to the thread, titled "anyone have experience with conex push fit" which is posted in Gaining Plumbing Experience on Plumbers Forums.
GBZ,
AWheating,
