Job: Replace pictured cistern
Green arrow shows were metal flush pipe has a flange under the nut. Not just just a straight bit of pipe. This was sealed to old metal syphon thread with hemp. The whole assembly is old, gunked and has been heavily painted.
If I were to attempt to put new plastic syphon thread onto flange and use existing nut what should I use to make the seal?
If it won't play ball or I have allignment issues - given the very forward position of the flush pipe on the base of existing cistern, I have felt it might be best to cut the 1 1/2" metal pipe where the red arrow is and pipe back up to the new cistern (reason for cutting there is that where the flush pipe disappears out of shot down to the pan it disappears half into the wall and I'd rather not disturb it by attempting to change piping all the way down the pan)
If I need to do this (cut pipe where red arrow is and pipe up to new cistern) what should I use?
I'm thinking I could hacksaw the pipe, use an 1 1/2" McAlpine multifit compression couple, then pipe up to just below the cistern in 1 1/2" plastic (using fittings to get right allignment.) Would this make sense? And if so what would I then use to join onto the cistern. Would another 1 1/2" multifit jion 1 1/2" plastic to a standard flush pipe?
