mutley racers
Subscribed
Jun 10, 2009
5,168
811
113
Hampton court, Surrey
The waste outlet is 1ft away from the back wall. Is there any chance? I will build a box 150mm deep for the concealed cistern so need a toilet that has the pan connection quite far back. I believe I have managed to do it once by swan necking a flexi but not sure if it's just an imagination.
I am not wanting to dig out the floor to alter and connect on to the clay.
I am thinking there has to be someone on here that has had a go
Vitra s20, or s50 . They are 150mm from the end of the spiggot to the back of the pan
Mutley you get the question mark multikwicks by mcalpine that might help, fitted loads of that vitra 20's victoria plumb or even ebay,
Not sure about names or makes but have fitted a few back to walls where the spigot has been well recessed into the pan which would give you loads of play,
Mutley, Where did you get a price for the s20 btw pan, I use a merchants about 15 minutes away from Hampton court, I would have thought they could do that for 120.
Masons plumbing in chalkers corner, sheen. They sell a lot of vitra toilets.
Here you go £120 inc vat . With a seat
Vitra S20 Back To Wall WC Suite : ukBathrooms
Ok, I am back onto this job now. This is my plan below. I hope I have calculated it alright. As the old toilet was so close to the door, i believe i cam manage a 40mm saving. It doesn't see like much but it does make a difference
