dles1966
I have had a 105HE fitted to run on LPG (Propane), having swapped the jet bar and changed the dip switch setting on the control board, everything works fine except that it appears that I have bought the wrong gas regulator on the bottle. This is a holiday home and therefore the heating/water is not used much so the LPG is via a gas bottle as a tank in the garden is a fortune.
The regulator I bought appears to be of the sort for camping and "low" flow applications and so when the boiler burners ignite I believe the flow is too high and so the regulator thinks there is a leak and shuts off? By holding in the overide boiler everything works fine.
The regulator is marked 1.5 kg/hour 37mbar.
Can anyone advise on what type of regulator is required? and where I might get one?
Alternatively what is the maximum gas flow rate into the boiler when running LPG and I can source the correct item.
Michael
Michael
