out of fifthteeen fitted twelve have had various problems, inlet test point is really hard to get to, washers pack are slighty oversized so really difficult to fit when fitted to minium height to surface, gas valve problems diverter problems won't waste anymore time on them anymore!
I read the instruction and follow what the rep told me, maybe I have been lucky but I think these are a really good boiler.
Think I am on about 10 now.
Please list all the faults you have had.
One thing for sure this is not just a plug in and play boiler.
have fitted one and had problems with it,customer supplyed boiler because of 5 year waranty baxi wont honour that now because i didnt register with works first there was nothing supplyed with the boiler to tel me this . do me and the customer feel like weve had our pants pulled down =yes . these boilers and baxi support are crap,worster all the way for me.
What problem did you have.
couldnt get it out of chimney sweep mode press the 2 buttons and display kept going back to 303 80, after spending about 50 mins on the phone to baxi and doing a re commition they said as it was working they would be round to look a week later, before week was up the customer had to phone them because heating hadnt come on they left him with no paperwork so dont know what was wrong.
In my opinion most of the problems are the engineers fault for not reading the instructions.
I always run the hot tap and have the case fully on before I fire it up for the first time.
At the moment I have had no real faults and have now fitted quite a few.
I would say there a great boiler for the money.
Baxi really need to change the set up of these boilers as most plumbers do not read or follow the instructions.
Not really baxi fault but they will get slagged off on forums.
I do agree there is some minor things that need to be changed.
The washers are to big.
The pressure gauge is hard to see.
The control panel is not of the best quality and doesn't close very well.
Now compair this boiler to any other in the same price range, the Neta Tec is by far the best. Ferroli or a baxi ? Lol
Hi all, i am a commercial gas engineer and have just purchased one on the above boilers to be fitted in my home. Not sure if i am thinking i have done wrong...
Whats with the self commissioning?
I was talked into getting this by there rep in plumb in Manchester, got a 28kw, with flue kit and remote clock/stat for £680, so was pretty impressed. Boiler looks simple and easy to work on (he had a demo there), 5 year gaurantee, next day call-out etc..
Any one any info about commissioning side, as that seems to be were the problems stem from.
Thanks in advance....
If you would like to ring me I can talk you though it. 01943876999
Tips.
Run hot tap all the time while setting up.
Make sure case is on do not start the boiler without case on.
Then just follow the instructions on the front.
I fitted a megaflow today and the set up is the same. Again I had no issues at all.
These boilers are very good. Most of the problems are installers not reading instructions or not following them.
Regards.
Thanks for the reply mate.
When are you available to talk. As i am not fitting until Sunday. Just downloaded the installation instructions and doesnt seem to bad. Just doesnt mention about running hot type while it is going through sequence.
Ring me Sunday if you like. Really easy to fit. No it doesn't say about running hot tap but I was told too do it by the rep before I fitted any. I have now fitted about 10 or so now with no problems at all.
Very good boiler for the money.
Cheers mate, expect my call at some point.....
Going from a Baxi bemuda 100 lol...
So just hope this is 100 x better....
System will need a really good clean out, if I was you I would put some deposit remover in system and run it around with old boiler for a few days. Then fit a filter such as a TF1
X300 be good enough?
I am replacing a couple of radiators on thursday night so will add it then. How much will i need do you think? 10 Radiators on my system. Got no were to install a filter as all my pipework in wall so not accessible. Unless they can be installed within the boiler somewhere???
Will also be added x400 when i have finished install or is it not worth it?
You don't really want to put all that muck in new boiler. I would flush it first and then just do hot and cold flush with new boiler in. I would make sure I had filter on return.
