L
luke2702
I didnt mean to write bumuda should have been bahama sorry.... Would you still use the diposit remover?
If its all plastic then you are right... Depends on system.. If there are any problems with water quality baxi will void warranty.Changed a rad about 3 months ago and all that came out was a bit of black water, had no slugs in the rad at all... All the pipework in my house is plastic with 10mm ends to rads. Should it require that intense treatment? (not meaning to sound that i am not taking your advice just curious)
If you clean it and fit a filter then you will be fine.... They don't try and get out of things, but they will not cover it if is black sludge....How will i know if the water quality is to there liking? As it must be a easy get our clause for them...
well,the clock has now had to be replaced as it was loosing 5 minutes per week.
on top of that, the error code 133 has emerged once again, 4 weeks after having a new valve fitted due to the same error code. this time however up to now, the boiler is fireing up, after useing the reset button, but it will not fire up automatically from the timer.
this boiler is now only 8 weeks old!!!
i guess it works ok in hot water..yes . On the front of divertor valve there is a wire connection. Pull it off and reconnect.. See if that works.. Thanks.Fitted one of these on monday. All seemed fine accept tonight were i have noticed that it doesn't want to modulate!!! Was modulating when fitted and all week (been observing it) Now in heating it just goes to 80 C cuts of then re-fires at 71 C. Any ideas heating-eng? WOuld have thought a PCB or may be gas valve. Commisioned with no problems.
Fitted 2 last week and again no problems, I haven't had to get baxi out once on about 13/14 boilers . The wire on divertor valve can catch on pull down flap and in turn pulls the wire out a bit, this means that the divertor stays in hot water only.the more i hear about the neta tecs the more i wont fit em,yes the heatmax has just 2 years warranty but lines longer it seems a boiler with many fickle problems (neta tec) but allens doing something right because all his installs work,read the mi,s anyone?
5 year warranty ends at end of month....then you need to pay extra for 5 year warranty.Thanks Allen, just done that and it seems to modulate now. Will keep an eye on it.
All i can say about these, is there are easy to fit, swapped from a bahama 100 and it only took 3 and half hours. Nice compact boiler and gives good flow hot water. Would def recommend to a friend. And good with a 5 year warranty...
