I'm sure your a fantastic gasman and not driven by the sell sell altitude of some others, I know what impact privatisation has had on the role of a gas service engineer for BG, to ignore the negative side of the sell sell cooperate driven attitude is as silly as saying all BG engineers are crap and need a PC to help get the case off.
A BG engineers credibility has been effected and it isn't the same as used to be, but I can only speak of my own findings.
Needing a laptop to take the case off pmsl
Yes If I come across a boiler which is new to me, then I will look at the manufacture instructions, isn't that what they are there for? The one thing with working for British Gas is I can't say to a customer "sorry, don't work on them" which Is what a lot of local firms tend to say. At British Gas we have to work on every appliance out there as long as its service listed. I went to work in Derby for a couple of weeks to help out in that extreme cold weather we had and I came across a boiler called a Wolf, thank god it wasn't service listed lol. Have you ever heard of a boiler called a Wolf?
A Potterton, 25 years old, has window in front to see the nice blue flame, which heats a cast-iron heat exchanger above the flame, the ash is cleaned from below the burner.
Is it a floor standing boiler? You say it's 25 years old, did you know the average lifespan of a boiler is 15 years old? And British Gas didn't make that up. Best advise is to replace your 25 year old very low efficiency boiler with a modern efficient boiler. The chances are, you can't get many parts for the boiler, but saying that, they don't make boilers that last that long anymore. You could get another 10 years out of your boiler, who knows but that's a chance that you take. Experience tells me that when boilers do break, it's more than likely in the winter months. I hope your boiler goes on and on and gets you through many more winters. Good luck.
The British Gas Service Policy requires completion of a generic service check, which involves carrying out essential safety checks followed by the use of a flue gas analyser to confirm safe and efficient combustion. Only when acceptable combustion readings cannot be achieved, or when a flue gas analyser is not available, or the operative has concerns, shall a full strip and clean service , in accordance with the manufacture instructions, be undertaken. A full strip and clean service shall always be carried out on back boilers units and back circulator units. The combustion case must always be removed to enable inspection of the heat exchanger etc etc.
Thank you for confirming what I have stated on this thread - I am talking about domestic boilers.
If BG were selling Home Care on the basis that an annual safety check is done, and if thought to be necessary by BG, a Service will be carried out, that would be fair enough.
As can be seen in their sales literature and their contract material, they say that an annual safety check AND a service will be part of the agreement, which obviously leads to most customers believing that their boiler has been serviced.
Based on what I've seen of BG over the last few years, their aggressive marketing has led to the quality of service being side-lined, and I do have plenty of documentary evidence to support my opinion on that.
I can see we will never agree on this, you have obviously got a real problem with British Gas. So I will say tara for now.
What part of Scotland do you work tamz? I was working in Aberdeen back in March for 4 weeks, loved it.
I made a mistake, the Potterton was the boiler in previous house.
My current house has a Gloworm Fuelsaver 80F.
BG have always kept it going for me, although advise me to get it replaced with a fuel-efficient one.
But at my age, I will probably not live long enough to recoup the capital expense by the amount of gas I will save!
Mainly east central but anywhere really if there is money to be made. Aberdeen is a good place to work away. Plenty stuff going on up that way. Last time i was up there was about 2 years ago now when they were building union square (the centre across from the harbour).
Thats the reason I am not a big fan of BG
How can you give best advice of replace the boiler and say some of the parts are not available when most parts on that boiler are ore than likely widely available. It scares the customer into thinking that if it breaks down in a cold snap then they will be without heat for weeks until they can get another boiler.
I do sell quite a few boilers working for the company I work for I dont get any thing for it and I dont do the hard sell on them just give them the options of repairing or replacing the boiler. But if I come to the likes of a Baxi Bermuda 25 years old I will never say my best advice is to replace it as that is not the best advice in that situation.
A fuel saver will probably last longer than you as long as it doesn't rot. Reliable easy to fix boiler. But saying that i once had a capri which was pretty reliable too but i have a land rover now not because it costs less to run but because i wanted one.
I think every part of the boiler has been replaced over the years, so it is "new" really ie much less than its actual 25 years.
How can you say it's not best advise to replace a boiler that's 25 years old? If I had a boiler 25 years old in my house, I'd replace it. I stated that you could get another 10 years out of it, who knows how long it will last, knowone does. But if I told a customer to stick with it, I wouldn't want to be going back in the middle of a very cold winter and saying "I'm really sorry mrs Jones, but I can't fix this boiler now as its so old and I can't get the heat exchanger which is leaking all over the kitchen and as its now our busiest time, unfortunately you have got a wait for a new boiler" I know what the reply would be from the customer, "you told me not to worry about replacing it" yes I know I did Mrs Jones but I never knew this was going to happen.
think about it mate, I'm not telling the customer they have to buy a boiler from British Gas I'm just explaining that my honest advise would be to start to think about replacing a boiler that's 25 years old, the customer wants my expert advise so I give it, simple.
The Energy Saving Trust estimate that a 15-year old conventional boiler may only be 60% efficient at converting fuel into heat; this means that for every £100 you spend on heating bills, £40 pays for wasted fuel.
When is the best time to upgrade?
As a general guide, boilers over 15 years of age are likely to be the least energy efficient and most difficult to source parts for if they should break down unexpectedly. Therefore it might make sense to replace an old boiler sooner rather than later.
[DLMURL]http://www.domgen.com/newslines/issue_2/boiler.html[/DLMURL]
So why not just say you cant a heat exchanger for it when you can more than likely still get the gas valve, thermostat and thermo couple and probably still be able to get hold of burner
[DLMURL="http://www.domgen.com/newslines/issue_2/boiler.html"]Newslines: Is your boiler ready for retirement?[/DLMURL]
It takes a lot to stir me up, but BG have managed it - as mentioned, there is a history to my current opinion of BG, besides what has been mentioned here.
If you are an advocate for BG, you should have some interesting conversations on here, because I'm not the only one who has issues with them.
Nothing personal though, I can appreciate that they provide everything you need and a good wage, so toeing the party line and picking up the salary cheque is fair enough.
