thanks for the constructive thoughts.... we over sized everything in respect to heat...
hot water is seperate...
we have double convector rads
we have a separate underfloor heating system.
the rads were for back up if it got really cold ....btw this is for a place in Estonia -10 to - 20 degrees in winter....
and ur right the boiler men here are crap ....but im muddling through ...we just keep adding apartments and adding more rads ...so this has been the problem ...the pump i think is not up for it...but i m not an expert ..i just want to fathom out the basics ...from sensible guys like u
just need some good advice... thank u have a great sunday ! waiting for some more answers...
hi the veismann 66 kw runs it all ok at the moment ...the boiler is running at 50 % efficiency ....and it handles it all ....
we only require a 22 degree thermostat temp.
hot water is ok at 43 degrees out put.
im not an expert at this but need to get to the bottom of this.
the question is do we need a more powerful circulation pump ?
in your opinion.
we have kept adding more rads over the time ...
i sent u a private message thanks for the constructive critisism ...but its not a wind up read and reply please...
hi thanks ...
i have 2 circuits
1 for underfloor heating which works great
1 for rads circuit just in case its not warm enough most rads are off as the UF does the main job.
but we added another 20 rads and they are warm cold hot warm ...on the top floors they do the same ...i hope its a pump issue ...
and would live some real points ....
i have a great guy but i wanted to hear others like u guys out..
thanks
ps just want to see some serious advice and what problems guys have encountered before...
jack
Disable weather comp and turn boiler upto max. Upload a picture of ufh manifold.
Sounds like boiler undersized . Is it open vent or sealed system. You need a second boiler as when that system is on full tilt it's going to struggle.
I'm available for a working holiday £4.5k should cover my expenses for a week??
I'll join you.
Can pay me to go over and sort it out, from what you have said it needs a different set up.
a bigger pump alone isn't going to help you one bit by itself!
haa ermi ill join you.
you can't run 55 rads off of 32mm flow and returns when it's -10 outside so here's your 1st problem.
The pump in the boiler will not be up to the job. Do you have hydraulic separation and an additional pump for circulation?
55 rads on one zone with 1 stat?
