Black plastic water supply pipe - please help
View the thread, titled "Black plastic water supply pipe - please help" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi, I've only just registered on this forum and hope there is someone out there that can help. I've just dismantled an old kitchen in our house ready for a new one to be installed. In the process, i unearthed a stopcock connected to the incoming water supply pipe which comes up in the middle of the floor about 2 foot away from the wall. This was previously below a kitchen cabinet and inaccessible. The only way we could turn off the incoming water supply was to turn it off from the external stop tap housed in a grid in the pavement outside our house, or use one of those isolation valves that you turn 90⁰ one way or the other with a screwdriver to turn it on or off. While the kitchen space is clear, i thought I'd try and tidy things up by moving the black water supply pipe near to the wall it comes in under so that the stopcock can be accessed through a hole cut in the back of the kitchen cabinet that will be going in that place.
The problem i have is that there are a series of connections all joined together that reduce the pipework from the black plastic pipe via a series of compression fittings which lead to a 22mm to 15mm reducer that then goes in to the stopcock.
I originally assumed that the black plastic pipe was 28mm outside diameter based on a quick check using a tape measure. I thought i could do away with some of the compression fittings by fitting a new 28mm to 22mm reducer and a new 22mm to 15mm reducing stopcock.
My first mistake. The black plastic pipe is not 28mm. The olive from the 28mm to 22mm reducer was nothing like a snug fit when offered to the plastic pipe. It looked like there was more than 1mm play.
My second mistake. I then thought the black plastic pipe must have been 25mm (i didn't remeasure to confirm this). I found a 25mm to 15mm reducing stopcock. Bonus... i could do away with one more part... the 28mm to 22mm reducer i thought i did need.
My third mistake. The plastic pipe is bigger than 25mm. The olive from the most recently bought 25 to 15 reducing stopcock does not fit over the plastic pipe.
I thought that perhaps it might be an imperial size pipe (the house was built in the mid 80s) but thought i should be more precice in measuring the pipe diameter. I got hold of a vernier caliper and measured the outside diameter. It seems it is 27mm having measured it at a few different places.
Question - is the configuration of this pipework from plastic supply pipe to 15mm copper pipe normal? Is anyone familiar with it and does anyone know what is needed to replace what is currently in this set up?
In case anyone is wondering why i dont just leave it as it is, there was a leak coming from somewhere amongst the compression fittings, somewhere before the stopcock. A plumber came and took things apart and suggested i take the whole setup to a plumbers merchant and let them work out what i need. When he'd left after everything had been reassembled, the leak was even worse. I took it all apart again and reapplied ptfe tape to all the threads and also around the olives this time. This appears to have stopped the leak for now but as far as im concerned, it's been patched up rather than fixed.
I can't take the whole assembly to a plumbers merchant because i can't remove the olive from the plastic pipe without cutting it off. I don't want to cut the olive off until i know i can get the replacement fittings back on the same day. Rock and a hard place you might say.
Any help and advice will be greatly appreciated. Thanks in advance.
Paul
Philmac 3G universal transition coupler 21-27 x 21-27mm | Wolseley
Into a 22mm stop tap then do what you want after either red to 15 or carry on in 22mm
Thanks for the quick response. So this basically replaces those compression fittings between the plastic water supply pipe and the stopcock/stop tap. Would i need an insert to go in to the supply pipe when fitting one of these? It looks like there's acopper onsert in the current set up which is stuck tight while the olive is still there.
You need to cut off a about 30 - 40mm and take it to a local plumbers merchants - not a mainstream one like wolsey ect...
If its the horrible thick plastic pipe I'm thinking of, it was put in during a copper shortage late 70s, all the fittings are glued and take around 4 - 6 hours to set
It's very common in my area, however you can now get a compression fitting which goes onto the black plastic
Black Polyorc 3/8" PVC Pipe to 15mm Copper Adaptor | PlumbinBits
There are many sizes that's why the merchant will need to see the pipe to slide the fitting on to make sure it's okay
Thanks for your reply. There is already a copression fitting attached to the thick plastic pipe in my set up - it could well be the same thing you are referring to, but something amongst the various compression fittings has failed. Not sure if it's going to work but I'm going to attempt to attach a photo of the set up I'm look to fix/replace.
Could it possibily be one of those old Elcetrofusion pipes?
Electrofusion Fittings
It could well be. I'm no expert. The only thing i do know is that I've measured the pipe OD using a vernier gauge and it measures 27mm (assuming the gauge is accurate). I can't find any standard fittings that are made to fit pipe of that diameter apart from the universal transition fitting suggested in the first response to my post. Does anyone have any experience of using one of these and are they any good?
Or black alkathene pipe?
If the electofusion pipe is very rigid and brittle, then i don't think that is what we're dealing with. The pipe installed is flexible. It had been bent over at 90⁰ and secured to the kitchen floor below a kitchen cabinet. It looks and feels like the material used for regular water and gas connections. Just an odd diameter.
The 25mm/32mm etc quoted with pipe fittings are nominal pipe sizes not the actual diameter, each maker may be slightly different.
I think it was Polyguard barrier pipe fittings I found in the end that were 2-3mm bigger than the quoted nominal size.
I come across this sort of thing all the time with a mix of old black alkathene to kennels, troughs etc as well as the now standard blue MDPE pipes around the smallholding & these universal adapters are a godsend - the days of boring out miscellaneous old compression fittings to use with o rings & ptfe tape to try to get a seal are long gone!!
You sound familiar with the puzzle I've been facing. I ended up getting one of the universal couplings suggested by ShaunCorbs. I haven't fitted it yet but intend to this afternoon. Reassuring to hear you have had success using them in the past.
Oh yes! We're on spring water here & there were miscellaneous tanks collecting the overspill from the spring tank to feed garden/kennels/troughs etc. Several different sizes of black alkathene,(there are different wall thicknesses in the same nominal size too! - so different OD for the same 1/2" or whatever pipe😱).
I've replaced the collection of old tanks with a couple of IBCs plus some "new" blue pipe - hence the need for "constructive solutions" involving lathes, compression fittings, PTFE & profanity! Those universal couplings are a breath of fresh air for these problems.
My house stopcock is like yours too, with a 3/4" black alkathene connection to a compression stopcock which originally fed 1/2" copper via a reducer. When I re-plumbed all in plastic ( we have very aggressive water which eats copper which I found AFTER replumbing in new copper originally in 1979 😡) I used a new 22mm compression stopcock with some special olives that were available to convert that specific size of alkathene to 22mm fittings. Touch wood it has never been a problem, but I have a spare olive tied to the stopcock just in case!
Hi all. I thought i'd post an update on the final outcome. I fitted one of those philmac universal transition couplers as suggested by ShaunCorbs. Problem solved. They are a bit bulky but better than what was in place before.
I'd like to thank everyone that contributed to this thread
Wont be polyorc it will be black alkathene
Reply to the thread, titled "Black plastic water supply pipe - please help" which is posted in Bathroom Advice on Plumbers Forums.
PDJ,
Millsy 82,
