Concealed cistern fill valve.
View the thread, titled "Concealed cistern fill valve." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
Has anyone got an idea what make concealed cistern this maybe? I need a new full valve for it. Thanks
Thanks what's happening with it is. Flush the toilet. It flushes water stops flowing in to bowl. It then starts flowing in to bowl as the fill valve isn't shutting off. It will stop for some reason if pressure the small button on the flush plate. Strange!
So anyone know what the blue but is sticking out if the thread? Worried this would effect the Flexi sealing?
Any idea why it just fills and won't stop. I presume this is a washer or problem with the arm. But then why it stops when the small flush button is pushed. Unless it's jolting it to shut it off.
Reply to the thread, titled "Concealed cistern fill valve." which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
Matt0029,
