Concealed / pre-wall basin waste conections
View the thread, titled "Concealed / pre-wall basin waste conections" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I am renovating a bathroom and seeking advice regarding basin waste pipe connections in concealed walls, pre-walls. Can anyone advise me what waste connection / socket is actually left in the wall in a scenario similar to this image assuming that the basin wall is internal and the waste runs vertically down inside the wall. I was hoping to have all the concealed pipes solvent weld but obviously the chrome trap pipe has to go into something?
file.php
Any advice welcome !
Cheers
Neil
Sorry for not being clear, the picture is just an example. My scenario is similar but I will be ripping out and starting again, I know will be using a chrome bottle trap and want to conceal waste pipes in the wall. I would prefer to have the concealed wastes solvent weld but it isn't clear what the the first "In wall" connection should be.
Everything behind the wall should be solvent weld, the last connection (outside of the wall) will be a compression joint.
Either
Some chrome pipes come sized to fit pushfit waste.
But I don't use pushfit.
Or an elbow or straight compression connector.
Reply to the thread, titled "Concealed / pre-wall basin waste conections" which is posted in UK Plumbers Forums on Plumbers Forums.
Neil Davenport,
S.P.S.,
