Condensate - Plastic tray, normal practice?
View the thread, titled "Condensate - Plastic tray, normal practice?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Is the clear hose squashed behind the pipe in picture 2?
We can help you out on here but you need to get the installer back as there is something not right with the condensate pump
I've edged the clear hose up and around the pipe, so it's not squashed anymore.
Should this make some difference?
The installation looks poor, but in principle it should work. Presumably your last pic shows where it's bossed into a sink or similar drain. Maybe matthias's #15 is right, no hole has been cut in the pipe. If so, easy enough to correct. If the pump is wired correctly and the hose isn't kinked, I don't see a problem. Get them back to sort it!
Only have to see the different water levels in the hose to see a problem, might even be the only problem!
Is there a joint in the hose or is it lens/ light trickery?
Op, don't suppose they left the installation guide behind did they?
Can it be arranged so that the clear hose goes vertically up and then flows to a drain point under gravity? I always think these work better like that, lift first. A bit like saniflo - ask RPM!
Having moved the host so it wasn't kinked, there has been little change in the issues unfortunately.
The pump still fills up within about 48 hours and has to be emptied as it starts whirring out loudly and not working properly.
I've not heard back from the installers, I do feel they are stalling quite a bit now - I've been asking them to come out for a number of weeks now.
I asked what the alternative is to having to keep changing the pump and I've been told all they can do is put the condensate into the stack outside, but they aren't supposed to do that. Surely my only 2 options can't be to change water from the pump every 2 days forevermore or to improperly have it going into the stack outside...?
Doesn't sound like the installers will be back tbh. Time to take matters into your own hands so check out some of the suggestions given earlier or start by disconnecting the hose from the boss and running it in to a bucket to see if the pump is even discharging.
Sounds like the pump isn't working. It should be possible to fix it. What type is it - diaphragm, centrifugal, peristaltic or what?
Why is there a pump anyway, is the boiler in a basement ? Centralheatking
Without trawling through all the posts again, I assume it's because the condensate outlet on the boiler is below the lowest convenient drain point.
Also noticed OP had been thinking of getting a combi but decided against. The condensate drain issue would be the same with that.
Centrifugal pump and doubt it is in a basement as OP said flat with limited room to run pipes that said I still stand by "Incorrectly installed".
That said, this system should still be totally workable and the pump should run and do its job properly once the issue is found and corrected.
The Grundfos and the Saniflo version of these little pumps can be wired in such a way that if the pump fails then it cuts the boiler hence I asked about the installation manual being left on site.
Agree unless the poor little thing is now buggered by pumping against a closed head.
Could be, but most centrifs draw less power at closed valve than at duty point.
Time the OP took it to bits and investigated. We've done all we can IMO.
Wasn't thinking of motor windings damage more of bearing damage and OP hasn't reported back on other findings so bit early to start dismantling it.
I would bet that your boiler benchmark form/certificate has not been filled in with the installer details.
If it has contact gas safe & request an inspection as you have no way of knowing if it has been installed correctly without an independent inspection.
Sounds like your installers may not be all they seem.
I would of been straight around to correct but certainly would not have installed like that as it looks a bit lashed up.
Hope you get sorted,
Andy (Allgoode)
It's never too early to start dismantling! 🙂
How will he diagnose the problem otherwise?
I would start at the solvent weld joint as advised then pull the hose back (currently runs down and back up - Big no no!) and lay it on the floor with the open end in a bucket.
That way you prove if the problem is the pump or the pipe run and take it from there.
I'd have thought the OP would have checked obvious things like blockages and kinked pipes before posting on this forum.
I can't see how it couldn't be fixed, or at least the fault identified, by somebody with a modicum of ingenuity.
Assume nothing, the OP could work for NASA but that doesn`t mean they understand basic plumbing 🙂
Agree re the fixing or fault being identified however I prefer to see if the pump is working before (Quote) "Taking it to bits". 😱
OK I think we can agree on that 🙄
Bet they got the holesaw out. And goodie...just because a benchmark hasn't been filled in on paper doesn't mean it hasn't been completed...you still living in 2015 or sooo? Apps these days pal.
Reply to the thread, titled "Condensate - Plastic tray, normal practice?" which is posted in UK Plumbers Forums on Plumbers Forums.
eleguj,
rpm,
