Nov 8, 2021
Cheshire
DIY or Homeowner
Well first of many posts I think, I'm currently in the middle of doing a barn conversion for myself and am now starting the bathrooms, I have not yet got any sort of boiler etc so I'm hoping pressures won't be a problem.
I'm installing a wet room and wanting to fit a fancy shower, I have looked at the Vado dia-2000 and quite like the look of them however they are only 2 output, I want a waterfall shower head, a hand wand thing, 6x body jets and also 2x jets or a shower head over the bench, the valve for this would ideally be situated separately next to the bench. So I would need a 4 output valve for the main shower and a single/2 way for the bench. Does anybody have any fancy ideas on how this can be done? I did wonder about some electronic gate valves and some ip rated switches from rs but think this might be abit difficult.
Thanks for the reply, I will be fitting a oil boiler at some point, currently this is a new build barn conversion so I can fit whatever equipment will be required for the pressures and flow. I would rather have the shower I want and then work backwards from there and get the boiler/tank required. The water is currently fed from a spring but am I right in saying that I can still have the shower I want if I fit accumulators etc, I have recently stayed at a hotel fed from a spring and the water pressure would take your hand off so can't see it being an issue?
External shed insulated enough to fit a dab easy sys and additional tank and uv and water filter gear before the dab kit
I have 8 meter square plant room located in a basement for all the heating/power/mvhr so room shouldn't be an issue. It's the shower valves and pipe size I'm struggling with. Not sure if I need a 22mm or 15mm, I plan to run dedicated feeds to each tap/valve/appliance so would say 15mm would be ok. But the valves I've come to a brick wall
22mm maybe 28mm depending on things check my links above for showers
Thanks for the links shaun, I haven't seen those valves before so was an interesting read, however they are quite big and are not electric/smart. I like the vado ones as they are nice and small, I think I might have to get the 2way one for shower and wand, and one for the jets, and one for the shower above the bench. I cant see the point in using 22mm if the valves are 15mm?
Maybe look up hydraulic gradient in water pipework then you will see why larger pipework can be required. Also remember high pressure don't always equate to high volume correct pipe sizing needed.
