Thank you for your reply. I believe it was a doc washer pack of 10 type A & B flat washers from city plumbing or Travis Perkins.It looks like the right washer , its just been overtightened .
Where did you buy the replacement washer ?
Sure it should be an MT washer you want to use mate.Thank you for your reply. I believe it was a doc washer pack of 10 type A & B flat washers from city plumbing or Travis Perkins.
Not sure what you mean... can you re-phrase?Sure it should be an MT washer you want to use mate.
Not really. Parts centre where I am call the washers that go inside drain offs MT washersNot sure what you mean... can you re-phrase?
I suspected you meant MT= empty=draw-off cock washer, but I wondered if you meant, are you sure you want to use a DOC washer mate? Or if MT meant something else. But fine, I get what you meant now, thank you.Not really. Parts centre where I am call the washers that go inside drain offs MT washers
