How would a wet vac help in this matter?If you have a wet vac, that is your best bet! Always a life saver so if you don’t have one maybe a investment you should consider
Use it to drain downHow would a wet vac help in this matter?
Don't have a wet vac. Never will. Another thing taking up unnecessary space in van.
But how would you use it to drain down on this system? Your point makes no sense mate.Use it to drain down
Close the valve on either end then then open then drain that rad with the wet vac, then open the valves an drain the system through there with the wet vacBut how would you use it to drain down on this system? Your point makes no sense mate.
Why not just use a hose? That is what the valve is designed for and a lot cheaper then buying a wet vacClose the valve on either end then then open then drain that rad with the wet vac, then open the valves an drain the system through there with the wet vac
