Drayton Digistat+ 3 hard wire problem
View the thread, titled "Drayton Digistat+ 3 hard wire problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
do you have a heating timer on the boiler or is it sep? if you do you only need a simple room stat
Drayton Digistat + Room Thermostat | Thermostats | NoLinkingToThis
[url]http://www.NoLinkingToThis/p/honeywell-dt90e-digital-room-thermostat-eco/41365
[/URL]
Honeywell CMT921 Wireless Room Thermostat | Wireless Thermostats | NoLinkingToThis
Got it working. The face on the programmer wasn't connecting the pcb board. As I had it screw too tight against the wall. It's clicking off and off now. Great.
😀 bloody plastic cr*p
good job for sticking with it
Yeah I know. When I remove the back case and put the front back on I heard the signal wire making a click sound to the boiler then it fired up. Thanks to your patience and expert advise now I have a new programmer working.
Thanks again.
Thanks again.
not a problem
Reply to the thread, titled "Drayton Digistat+ 3 hard wire problem" which is posted in UK Plumbers Forums on Plumbers Forums.
Dave Box,
ShaunCorbs,
