if you're getting a good flow out the hot taps the plate aint scaled. if as you said you follow the logic diagram using sw1 and sw2 you can bring up the hot water flow temp as the thermistor is reading it. if you, re getting intermittant 85c readout its more than likely a thermistor fault which is common on boilermates. changed loads of these
