Called to a customers today to look at their boiler. It's installed in the loft with a standard 90° elbow out the top of the boiler and straight out the wall. Both inside and outside are sealed correctly and flue is set at 5° incline as per MIs. Problem is that on the inside of the 90° bend there appears to be no more than a drip but definitely some condense running back down to the top of the boiler where staining is evident. I have checked the joints of the flue thoroughly and am satisfied that they are tight and under no strain from the incline. Does anyone have any thoughts where this drip may be coming from?
On a funnier note I've never seen anything like this guys loft he has a plastic container under EVERY joint in the pipe work. Just in case they leak. It's a pressurised system so I asked what happens if the joint gives at the side or on top, I don't think he understood. Cheers all
