stokecity
137
13
18
hi guys got a vaillant eco tec pro, boiler not firing or even attempting, display screen is showing random numbers such as 888, 858 most of the time its showing part numbers i.e as if the numbers are cut in half horizontally, not to sure if its pcb or display has gone so not showing fault code for somthing else
any input would be great cheers
Sounds like display pcb. Have you tried turning the power off for a minute or so then back on to see if it clears it, but I reckon the display has gone
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
