Looks like I’m wrong then.
Service one of them today. My 3rd job of the day. Combustion seal just crumbled on me.would that be the solution?
the old boiler must have been BAXI 100 HE
So you are saying I have to swap my pipes around? Are you saying the 2ay I have conntected it up is right? According to manufacturer yes. But why did the previous installers connect this the other way around?which is correct
return get too hot sensor shuts and re passes the return to the flow
im guessing hes wired something out
your problem is the cycling due to no heat load
Really, pretty crappy boiler to be fair.Service one of them today. My 3rd job of the day. Combustion seal just crumbled on me.
I love working on them. So easy.Really, pretty crappy boiler to be fair.
True! These are very easy to work on. A lot of space to be fair. These boilers are very heavy too:/I love working on them. So easy.
So what would you just me to do?
🙂 will do if I meet home in person.correct way as youve done it
dont have a clue if you see him ask him 😀
But what should I do now? Take the pump out from the ufh and let it run from the boiler pump only.
Could you give me an answer in what the way forward is?
Don’t know how much heat load it has got. But how comes that the pump at the Manifold works against the boiler pump? It does not make a sense at all to be fair. I do not think that the whole setup is correct the way it’s been done. The boiler pump pushes I to the top and the manifold pump pushes right back ...whats the heat load of the ufh i would be surprised if its over 5kw thats really your issue can you down rate the heating on vaillints ?
So, weird that there is written flow and return but pipework has to be fitted the other way around. But thanks a lot for your help shauni.after much looking your set up is a rehau manifold hkv-d with a
fixed temp control set
and it was piped up correctly
Yes you can matewhats the heat load of the ufh i would be surprised if its over 5kw thats really your issue can you down rate the heating on vaillints ?
