I want to install an Essex Flange to the cylinder for a shower pump. (Cylinder is surrounded by shelving plus is about 15 years old and has overlapping pipes at top connection so I'd prefer to drill a hole in the cylinder and leave the older connections alone)
The flange I have is the E1R type
3/4 inch with no compression fitting. Can I use male couplers on either side of this type of flange to connect 3/4 inch pipe to and from the cylinder? Or would you solder some suitable brass threads onto the outside of the flange to convert it to a compression fitting type flange? Is it advisable not to have a compression fitting inside the cylinder submerged in water permanently? Would really appreciate any advice. Thanks very much in advance!! (Sorry for sending PMs of this to a few guys!! My first time using this!)
