PSH
Ermintrude has got me thinking - I did wonder whether the system could not handle the piggy backed rads, but what is puzzling is the fact that there are 6 other rads on the system,sharing 3 other feed and return legs/runs using "T" connectors which are running perfectly hot . The work colleague who helped me do the job seems to think that the reason all the other runs are working is because on the run which is not working ,the feed and return pipes come up vertical into the ceiling ,then run along the top of the plaster board ,then start to rise on their approach to the return manifold,which he thinks could be trapping air bubbles which the water flow cannot shove along to where the auto vent valve is located. Q: Do you think I should try and level off these pipes so that there is no gradual incline on the run ?
