N
nysk2008
Hi all,
Having a bit of a garage clearout and am selling the following either a job lot or seperate:
Flue
1 x multifit horizontal flue including elbow part number 5118489
110mm
2 x Grey solvent AAV
2 x 90 degree pan connector
1 x D/SW short bossed
1 x 90 degree
1 x 90 degree coupling
2 x 90 degree (1 end female solvent the other male rubber)
50mm & 43mm solvent
10 x 43mm 90 degree bend
9 x 43mm 45 degree bend
5 x 43mm 90 degree street
1 x 50mm equal tee
1 x 50mm 90 degree bend
1 x 43mm equal tee
1 x 50mm straight coupling
Brass
1 x 15mm comp gas cock
1 x 15mm comp x 1/2 male straight
1 x 15mm comp x 1/2 fem backplate
1 x 15mm or 22mm comp pressure reducing valve
2 x 22mm comp stopcock
7 x 15mm x 1/2 fem service valves
3 x 15mm comp single check valves
2 x 22mm comp lever valves
4 x 15mm straight washing machine valves
1 x 22mm x 15mm centre comp tee
3 x 22mm comp ball o fix
1 x 15mm comp caleffi aav
1 x 15mm comp 90 degree
4 x solder drain off's
Copper
35 x 22mm coupling
7 x 22mm street elbow
13 x 22mm elbow
3 x 22mm x 15mm centre tee
2 x 22mm tee
15 x 15mm street elbow
44 x 15mm coupling
33 x 15mm tee
7 x 15mm elbow
Pushfit (mix of JG and HEP)
7 x 22mm equal tee
6 x 22mm coupling
7 x 22mm elbow
12 x 15mm equal tee
13 x 15mm elbow
1 x 15mm coupling
1 x 22mm x 15mm centre tee
Loads of 15mm/22mm inserts
2 x JG 15mm x 1/2 fem
Consumables
5 x 500g unleaded solder
4 x 150m loctite 55
1 x 350g fry powerflux
Stuff
1 x fluidmaster pro 45b
1 x used pcb for ideal icos he12 (working fine)
1 x used head from mid position acuator with wiring (working fine)
Cheers
I'll give you £50 all in for the brass, copper and consumables.
