H
Hoolie Helen
Hi
Does anyone know where or if I can get a flue for this boiler. I would also need (I think it is called the elbow joint flue bit) and an extension to go through the wide stone walls of the house?
Seems that this boiler that was only fitted in 2006 is a bit of mare to get parts for but would like to try as I;ve been told that maybe I should cut my losses and get a whole new boiler. AAAArgh too much expense after Chrimbo!!
ask baxi for the part number for the flue for a solo he they are the same,whats wrong with your existing flue?
Hmm well been told that the exhaust fumes go out but the oxygen?? doesn't come in and was shown a bit of blue stuff which I think was the seal. The flame goes high??? and then cuts out. Found a flue which was gathering dust in some shop but it is the elbow seal that has gone. Also the house has thick walls so flue not long enough and need an extension.
