Mar 23, 2013
39
Hi all, I have a tricky problem with a lead waste pipe coming from my bath in to the communal stack at the back of our house. As you should see in the photos the pipe is cracked between the cavity walls making access a tad difficult. The bath is an old cast iron with the original lead overflow and waste, so I don't really want to disturb this in order to pipe back the way in plastic to a new rubber bung in the down pipe. Can anyone advise on the viability of a lead repair and how to go about this. I am experienced in lead welding but not on this kind of problem. Cheers. Nick.
I'd be looking to replace all the lead, but if you need a quick fix,
Cut the wiped joint off close to the cast iron (brass spigot into iron?) and use 2 flexible couplers with a short piece of plastic to join them, should give enough to allow for the angle currently on the lead;
Flexi Waste Straight Coupling 38-45mm | NoLinkingToThis
now your at this stage replace the lot, its obviously pulled apart under movement, so will again
As the guys say ,,,,, some kinda stress has caused the cleavage
Its goin' to be a ripout job
Silicone CT1 sealant will seal most things even on wet surfaces . If that doesn't work replace the lot with plastic. Looking at size of split your photo is showing I would replace the whole lot with plastic.
Thanks guys. This prob has gone unseen for 3 years till we moved in a few months back. Luckily I have a snake cam for insurance work. The leak is on bath and shower waste so the foundations have been gettin soaked for a long time. What looks like a bulge on the wall is prob the tide mark from the rising damp caused by the leak. I think you are right to suggest renewing back to the bath in plastic. Hope I can source a 40mm bung for the cast iron down pipe. Cheers.
Wondered how you got that excellent close up shot of the pipe. What snake cam have you got?
No-one is wrong aplombiere . I think lame is aware that bricking in and pebble dashing a quick partial repair makes no sense. So like you all say... Bite the bullet and replace. Cheers.
Lame would like it. The guy suggested he didn't want to change the whole lot so gave an alternative . But do agree it would be better to change whole lot as stated in post. Not just giving sarky remark as lame did
I always try to do a decent a proper job and in never involves silicone botching, so I get incesnsed at anyone advicing someone to do so, we are supposed to be decent tradesmen not diy have a goes. if advice deserves some sarcasm then so be it, I feel its deserved
The house is solid 1930s . No movement. So I suspect the last have A go plumber pulled the bath away from the wall and fractured the pipe. Old cast iron bath with original lead waste and trap... So going to be a messy job converting to plastic. Bath has been restored and is mint girlfriend loves it so I got no chance replacing.
