GQuigley67
5,073
654
113
Roon aboot the roonaboot
anyone recommend a good multimeter ?? my cheap one is knackered so want to get a decent one, would like a simple one to use which has one setting for ohms and buzzer for continuity and preferably a magnet to be able to stick it on boiler casing.
that better ?
Display Type digital only
Brand Name:CEM
Measuring Capacitance Range:100uf
Dimensions:229mm x 80mm x 49mm
Operating Temperature:0-40C
Measuring Voltage Range:600V
Measuring Current Range:1000A
Measuring Resistance Range:40M
Model Number DT-3343Weight:303g
Anton do a good auto range one. I got an Ethos multimeter from city electrical factors. If you have cash to splash then I would buy fluke.
I've still got my 1980s Metex Testlab one from when I was at college!! Cost a fortune then (well to a student, about £60 I seem to remember!). Does all sorts of clever stuff like measure capacitance, inductance etc which I am unlikely to need anymore!
If you're planning on using it as a voltage indicator it must say on the certificate that it is suitable (theoretically that is).
UK Plumbers Forums
Deleted member 120897
