Green pipes?? Sticky residue?? WTF??
View the thread, titled "Green pipes?? Sticky residue?? WTF??" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Jennie
Hi all, I did a LGSC today, on a 1-year-old Worcester combi.
Pics attached of the flow and return pipes to the boiler, coated with green powdery but dry residue. And also the pipe tray/cover, which had a sticky green residue. No other issues anywhere. But because it's just the central heating pipes affected, I'm a bit puzzled. Any ideas anyone?
I thought flux too, but what's it doing around the compression nuts on the flow/return pipes.
Could be as Shaun says, but I’ve known people to apply flux with their fingers and then it gets everywhere, a long shot but could happen.
I would go with both Shaun and CBW - it is not verdigris ( copper reacting with Oxygen and moisture ) / that won’t form or adhere to brass fittings
But don’t do it too far in advance or they turn to mush and fall apart.
[automerge]1568877858[/automerge]
Some seem to have a coating on and take ages to seal up , others double in size from moisture in your fingers - don’t pre wet the latter.
I've seen leak detector spray leave a green sticky weirdness on pipework before after it was prayed on and then just left. Could that be the cause here?
Reply to the thread, titled "Green pipes?? Sticky residue?? WTF??" which is posted in UK Plumbers Forums on Plumbers Forums.
Jennie,
Stigster,
