Jesus, how do these guys sleep at night or even step back and think that lump of rubbish is a good job!
Anyone who fits plastic pipework straight to a cylinder like that is either an total charlatan who frankly doesn't care a BLEEEP what anyone thinks....or B - just a dopey DIYer.
if we could identify some of the halfwits that done the work in the piccies on here we could have our own song for them
standing in the hall of shame,
eveyones gonna know your name,
you be embarrassed coz we know your as rough as fk,
your a champion,cheap as chips champion,your as rough as a badgers rse,
standing in the hall,in the hall of shame
Reactions: 4 people
ImageUploadedByTapatalk1363821631.719096.jpglmfao!!!
Reactions: 2 people
seriously thinking about doing this mark, seriously.....
That is a typical bathroom job done by a builder !!! Not sure also but looks like waist is running up ?
MI have seen few bathrooms installs like this in Ruislip London done by a " plumber " , that is what the customer is
let to believe
let to believe
Can't be a builder there's no polytetrafluoroethylene on the isolation valves.
Reactions: 2 people
Definitely done by a plumber. But a bad one. The cold feed to those taps runs straight up from the kitchen and its vis able all the way up until it goes through the ceiling. Airing cupboard is half done in plastic. 15 mm push fit looks bad but in my opinion 22mm push fit looks even worse. Terrible job
And I'd lay a fiver that's a flexy pipe from the pan outlet. And the Dunny is piped in barrier from below. Yep the waste is going uphill so that'll be blocked by now. And he cut the hole with a 50mm core so there's a nice draught through there. The customer probably thinks it looks the terrier's testicles.
The house is actually a relative's of my Missus. They've only been in a year. The plumber the owner had before is obviously a joke. There's other things round the house that are bad. The kitchen ceiling has a ruff looking plywood board screwed into it where the shower trap is too low and had to cut into ceiling below.
The drain valve at the lowest point is buried in the wall so I used one of those self cutting isolation valves to drain system then cut that section out and replaced with a new drain valve.
Cowboys really make a plumbers job hard
V
UK Plumbers Forums
Deleted member 120897
