HALL of SHAME PHOTo`s
Riley,
Why not the water in the cistern is much higher than the connection of the sani-flow, I know you can't polish a turd but it will dissolve, be OK until
something big got in there and then go look for a plumber with a website who specialises in this sort of thingy!!!!
Would that be you Happy?
According to the customer it`s worked perfectly for 1yr 11.75 months then packed up just inside the 2yr warranty. You can imagine my reply.
Mainly used for number ones and not number twos, we need to know all the facts RPM before coming to an informed conclusion
RPM not me, but I know a man who can, its not what you know it's who you know, like you say RPM sometimes it's hellish hard to believe
anyone who says they never had and problems with it, BTW what was the problem, don't tell me it was blocked please!!!
The only fact I`m interested in whilst the van is on double yellows outside the shop is ...........
Not installed to Saniflo guidelines, refer to installer. lol
Might be best if I add that everything to do with the basin pipe, the sani and the discharge pipe was wrong so I would of been there for hours correcting everything on what was a warranty call and therefore no guarantee of payment as the owner wasn`t around.
The boiler took the full brunt of the fire tightness test fine boiler ran and passed fga no problems at all I was a bit worried about the flue so recommend a replacement they said just change the boiler
All of the showers leaked when it was pressurised! The tray was amazing upstairs this was the sauna room.
Shnizzle
Think they must of took a week with a hole cutter to do all the joists
Then ran 10mm for 10meters no wonder the fire was under gassed
There are some great photos on here and I'm sure there will be plenty more being added so I will keep having a laugh. I mean look. ��
Yes the ufh is off the unvented ...... Yes it's powered by a 12kw RI. No there isn't any blending on the UFH. No it don't work. Yes the installer was qualified. No he didn't have a clue. Yes I'm charging £75 p/h to a colleague to fix it. Yes I'm getting money up front. Yes it's hilarious and I can't help but laugh.
Barry98,
Harvest Fields,
