surely this never worked???
According to the customer it`s worked perfectly for 1yr 11.75 months then packed up just inside the 2yr warranty. You can imagine my reply.
Riley,
Why not the water in the cistern is much higher than the connection of the sani-flow, I know you can't polish a turd but it will dissolve, be OK until
something big got in there and then go look for a plumber with a website who specialises in this sort of thingy!!!!
Would that be you Happy?
The only fact I`m interested in whilst the van is on double yellows outside the shop is ...........
Not installed to Saniflo guidelines, refer to installer. lol
What the hell happened to that logic?
the plastic flue was brittle
might as well whilst making an insurance claimThe boiler took the full brunt of the fire tightness test fine boiler ran and passed fga no problems at all I was a bit worried about the flue so recommend a replacement they said just change the boiler
Needs more flexi....
Sheesh, must be DIY surely?
At least they have made it easy for you to get 15mm in there when you re-pipe.Think they must of took a week with a hole cutter to do all the joists
Then ran 10mm for 10meters no wonder the fire was under gassed
