HALL of SHAME PHOTo`s
Pressure reducing valve has been fitted on lower floor. Going to be fun servicing it. :smile: Relief valve obviously wrong place also. Whoever did this work definitely is capable of doing copper pipes and soldering neat, but I can't understand why they have the heating pipes to coil just straight out from connections taking a lot of space up.
Think that's a megaflo so it's got the internal one
Yes, it is indeed a Megaflow, so as you say, it has an internal air gap.
Workmanship not really deserving of Hall of Shame, but pity the plumbers couldn't have done it better and to proper unvented rules. The combination valve shouldn't be elsewhere and the separate pressure relief valve and its d1 needed above and dropping into tundish
sorry for bad light the sun was out 😀
mastic every where holding the flue onto the unit and holding the bricks inplace
I bet those bends were off of the original system, have to admit the bloke must have known what he was doing (if it works) because I get travel sick just trying to trace it!
Barry98,
Harvest Fields,
