HALL of SHAME PHOTo`s
saw this on another forum
Don't know what's worse, someone fitting an Ariston, or someone that couldn't be arsed to cut the flue.
Could have done with an Ariston flue kit
Then..
He's not got a gradual fall from boiler housing.
All condense must be weeping from flu outlet spigot
Gravity solar pre-heat to cylinder feed cistern (lid removed for clarity). (No vent as such from solar, but very small low-power design, so no risk of boiling). Vent from DHW cylinder is 1/2" copper into side of cistern. Draw-off to cylinder is from the bottom (coldest part) of pre-warmed feed cistern. Ballcock is on far side so literally impossible to get access to replace washer. Plastic CWSC hung on wires through ceiling from scaffold poles above ceiling. Improvised overflow hopper made from washing-up bottle. This photo doesn't do the installation justice, but it's a start.
Guess the fact that you directed the photo my way means it is to do with macerators therefore I see six (?) individual discharge pipes where one would do. Unless there are other reasons that can`t be seen of course. 🙄
6 mas yes
Barry98,
Harvest Fields,
