T
tforbes-turner
Does anyone know where I can get hold of 'Cice' 40mm ceramic disc cartridge cassette for a single lever kitchen tap.
I've tried searching everywhere and the only supplier I found wasn't too helpful and they are out of stock.
Thanks🙂
Thanks Tom. Its a make called 'Lacroix' presuming French! The actual cassette has Cice France on it. I've tried googling Lacroix but no joy as yet🙁.
Toby
any idea where it was bought from?
you could take it down to a plumbing merchant and ask at the counter, try PTS, CPS etc
Other than that with all the messing around probs best to change the whole tap, their not too expensive
Searching for these things can be absolute ball ache.
I find that if its a job your doing for someone,the best way of sorting the problem out is to have a quick search round then fit a new tap, (if there cheap enough) like Tom says.
Try these geezers, [DLMURL="http://www.lunns.net/tapspares/"]Lunns Tap Spares[/DLMURL]
Yeah they are good for bizarre drop valves from years back if they are concealed and a bugger to get to and you need an exact swap..
