WHPES
4,830
590
113
North Yorkshire
Hi. Got a problem - Riello RDB burner, motor is knackered but I can't get the fan off the spindle end to replace the motor - hub seems to have siezed, tried WD40 and heat but to no avail. Before I take the angle grinder to it and trash the fan, anyone got any other ideas?
yes, a fan puller. like a clutch puller for a car. right tool = right job = right result.
oh, sorry, i made an incorrect assumption.
it sounds like....er.....it's stuck and it's a cut-it-off job. pain in the bum.
good luck with it.
take the entire unit to motor rewinder. he will rewind the motor (fix it) and sort out the fan for you. !!
i'm sure i said it was the fan (another post - blowing my own trumpet)
Yes, I've been using the grub screw hole to squirt the WD40 in.
I already have a spare motor. I'm going to have another go at heating up the hub with a pencil torch to get it off, and if not, it's the angle grinder........ and order a new fan.
surely by now you can get a new riello burner for £250??? or dont you keep them off the old boilers and recon them.
We used to clean them up, then if we got a pain in the bum repair would change the nozzle and blast tube, re-commission and it charge the customer for a recon burner. They were happy, and we could work on the troublesome burner (like your jammed fan) in the workshop.
I have two Riello RDB1s on the shelf but they are both missing motors.
I told the customer it would require a new fan and that it would be about £20. It's not htat I didn't have the spares, it's just that the customer being a right tight arse said for me to leave the burner with him and his mate at the garage would get the fan off. He phones me today and says it's all there, but of course the fan is so distorted it won't fit in the housing anyway, so I came back and fitted it up with the new fan, meanwhile his missus has been banging on about not having any central heating during this cold weather, which of course I replied that it would have been going a week ago if her husband had not intervened!
Hee he he he!
