C
Carl86
re: Hints, tips & secrets of plumbing - No Banter please!
What i tend to do with solvent weld fittings (say 2 45's at a certain angle) is place them on the desired length of pipe with out glue that you join the two with then mark a line across both of them with a felt tip, or pencil.
Then glue up the pipe and fittings and twist the fittings to marry the line up on both fittings and pipe. Leave to set.
This piece can then be incorporated into the pipe work at the correct angle.
