Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
re: Hints, tips & secrets of plumbing - No Banter please!
When opening the upstairs taps at the basin (to help with draining the system) when turning the water back on at the kitchen sink, make sure uv closed upstairs taps 🙁
When turning water back on in a house, make sure someone hasn't opened some of the taps & not closed them & left a face cloth or a bar of soap on top of the waste hole!
Buy some penetrating oil, really handy for stubborn nuts, old rusted fittings, seized screwed pipe (when heating the joint doesn't work) etc, comes as a spray and looks like WD40, mine cost me £2 (rp-90) and has saved me on numerous occasions.
How to make a 10mm - 8mm reducer (end feed)
Slice off a short piece of 10mm pipe
Ream the burr out of the end
voila
you don't need to slice off a bit, just solder the 8mm into the 10mm if joining the two. i suppose if increasing to 15mm then you could do that.
Avoid losing compression fitting nuts down the pipe by clipping clip on pipe clips temporarily below the nut.
Avoid olives slipping off by squashing them slightly between your fingers before putting on the pipe so that they grip it.
Joss sticks are cheap (and better smelling) means of identifying air draw into flues etc.
If you ever remove a redundant or broken magnaclean filter, keep the powerful magnet.
Strip it so it's just the magnet, and tie it to a length of string. Dunk this in the machine when you're powerflushing. Apparently it speeds up the dumping process considerably (much like the inline mag filters for sale do).
Also on a radiator that is known to be more seriously blocked. Wrap the magnet in a soft cloth (or magnets if you're fortunate to have ripped out more than one). Then run this up and down the radiator. It will agitate the magnetite inside the radiator and allow for better powerflushing.
I can't take credit for these tips. A mate of mine who's a plumber sold me a couple of magnacleans last weekend. We had a quick chat and he offered up these gems. Make good sense.
Now I just need to find someone who has a leaky magnaclean so I can pilfer the magnet!!
Neodymium means nothing to me!!
I know the ones on the magnacleans are bloomin strong. First time I fitted one.........I got it out the box, and spent ten minutes picking up car keys and the like with it!!
I have a small very powerful magnet for detecting magnetite in pipe work (an ultra strong fridge magnet). I would like a massive powerful magnet for the tip my mate gave me as above. I'll take a look on eBay. Thanks.
Old computer hard drives are a good source of ultra strong magnets.
large bolt cutters are handy for quickly removing pipework up to 15mm, never worked with a set big enough to do 22mm but it saves time when ripping out a heating system
I was taught: LSX on the olive of every water bearing compression joint, always, every-time, without fail.
why would you do that? Surely no jointing compound is needed on a compression joint on clean and undamaged copper tube
I don't know, insurance, that little extra? What I can tell you is that i've never, ever, had a leak that I know of on a compression joint i've made, ever. For me, that's enough to warrant continuing what I was taught 🙂
who told you that??????????
QUOTE=Subby;357900]why would you do that? Surely no jointing compound is needed on a compression joint on clean and undamaged copper tube[/QUOTE]
copper cones do play up,plumb blue or similar is fine cures most issues lsx is way over the top its the same as apyling silicone to every joint
Agree with other posters lsx could mask a slight weep, and cause a later disaster.
Guy who I trained with and still work for. Plumbing and heating engineer of 35 years.
LSX causes big issues,have found numerous blockages in systems caused by it
Well then I'm sure you've encountered the results of some people misusing LSX in some way. A smear on the facing olive side, mind you, has resulted in me never ever having a leak on a compression joint.
Paste every compression joint & NONE will leak or have microscopic weeps that seize & corrode outside of fitting.
Use Jet Blue as it is non hardening & does all types of work.
I tend to use it on pump valves - i like a bit of extra confidence when i've been fighting with a 28mm compression in the back of an airing cupboard.
copper cones do play up,plumb blue or similar is fine cures most issues lsx is way over the top its the same as apyling silicone to every joint[/QUOTE]
quite right
Don't carry foam filler and a chainsaw (or any sharp object) in same hand.
tips wanted: how to remove cured foam filler from clothes.
one i remembered from pluasne
make an air test kit by stripping the rubber off an old tyre schraeder valve and solder it into some 10mm (i think) then solder into a 10x15 reducer connect the 15mm to a compression fitting, get yourself a foot pump and away you go.
KJ
What a brilliant idea ive tried to come up with a way of doin this for years ...if you were to use make up a little section with 2 valves you could also fit a tyre pressure guage.
Thanks Kay-jay 🙂
no need to strip the rubber.
put the whole tyre valve, rubber n all into a 15mm compression nut.
crank the nut down onto a 15mm 't' compression and branch from there to meter and pipe work.
I havn't tried this yet but isnt it a bit small for a 15mm or are you saying crank the olive up real tight?
found out today that used electrical elements such as in night storage heaters can be weighed in as brass :smug2:
Store your 15mm guide in the handle of your pipe bender.
Edit: And invest in a better camera. :shame:
stick a pipe clip on rad pipes when installing valves to prevent compression nuts sliding down and disappearing beneath the floor. or use a couple of wraps of ptfe around the pipe.
KJ
you could also press your pipe slice onto the pipe above the floor and remove it after work is done !
Yes it pops off. The teeth on the grab ring are softer than the chrome so can't bite onto the pipe. Always file it off....
Oh well thanks, the other night it was late and I only had a pushfit and a chrome elbow left whilst fitting a bathroom radiator.....looks like I need to go round and freeze it and then change it for a comp 90....
Thanks for the advice, looks like this may have saved me a BIG issue.....
Just arranged a call back and the customer thanks you also.....
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
