Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
re: Hints, tips & secrets of plumbing - No Banter please!
Yes, I hear this tool exists. Wouldn't trust pushfit on chrome ever though!
When replacing a soil stack in the Liverpool School Of Tropical Medicine remember to turn that 15mm isolation valve in the snake room back on which was discharging into the stack - it's part of some weird humidity control system which keeps the snakes alive which in turn are essential to the anti-venom research.
Yup, I almost killed all the snakes because I forgot I'd turned it off.
here here how many times has this been the after thought... gutted and thirsty lol
How many times have you took off a sink trap and asked someone to tip it down the sink while you're still under it?
Me - 3 times!
Remember to put the pipe you just cut out with the hole in it far away from you.
I was replacing the pipe after it had been screwed through and thought 'oh, look at that. This piece fits nicely. Lucky me.'
Recommissioned the system and flooded the downstairs flat.
yeah i got one , its just like a scoreing tool, you push the pipe in hold the nail type bit against the pipe ....job done,
i got it off a rep at a trade show with PTS, just asked him for the set ab
nd he gave me it at the end
Carry baby wipes. Excellent for getting silicone off your fingers.
Put a NO SMOKING sticker in your van in case you get pulled over by the council 'tards.
Once you have eliminated all the obvious whatever is left, no matter how unlikely is probably the answer.
If you've drained down always change the washer on the DOC.
It's bound to drip at four o'clock on Friday!
Flexi pan cons.... You can cut them down. Ping the end off cut it down and push/smash the end back on. Hard work but is possible. No sealant needed.
If making up a screen with the soft headed screws dip the tip in some silicone grease makes it easier to get em in and less chance of rounding the heads out before they are tight
Top banana! Hate those little beggers!!
dont buy rothernberg strips you can get a whole roll of this mesh from toolstation for a few quid and cut it up
Always remember to leave the cistern full when emptying a cst...........saves the red face when the owner uses the dunny after you dumped a richard...........doesnt smell like fresh cut grass either.
if your working on site,and someone upsets you,get into there motor,and set a smoke bomb off.
tell them there motor is on fire.
works a treat.
Dont ask an apprentice with an iphone addiction to keep an eye on the hose whilst draining down.
save all the old radiator bleed pips to replace rounded ones.
an auto airvent body and bent F/I make a good inhibiter funnel for compact style rads.
when changing a diverter valve on a vaillant turbomax, after draining the primarys whilst talking to the customer..dont forget to switch off the main cold feed before removing the diverter valve..lol
weve all been there!!!
If trying to take apart a seized brass fitting, heat it with blow lamp then dunk in cold water - the expansion and sudden retraction will usually free up the seizure.
Opps is daisy
If you are a scrap peasant like me, once you've stripped the insulation off a HW cylinder (btw Im about to try a wire saw for this purpose) - use an angle grinder and thin cutting disc to cut the welded joints off then cut the coil out and tada - you have twice the value in bright and a little bit of brazings..instead of the regular cylinder price.
Nice tip Spock lol just waiting for its only logical!
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
