Oct 16, 2018
41
England
DIY or Homeowner
I have a Worcester heatslave 15/19 oil fired boiler. The expansion tank was recently replaced however I am still having issues where the hot water pressure is not consistent.
Examples being you run the kitchen tap and it seems to take a while for the hot water to come out but then when it does come out it runs hot and is fine.
In addition we have an oldish triton shower which has a thermostatic mixer the water from the shower will run hot for a while then runs cold and goes in this repeated pattern. I am confident that there is no issue with any fault on the shower, when the shower is running you can feel the hot water pipe elbow joint next to the shower unit and can feel the pipe going from hot to cold in sync with the hot and cold water coming out the shower head when it should just be consistently hot.
All the radiators were bled after the expansion vessel was fitted and the bled valves on the boiler have also been bled. The motor is fine therefore after doing lots of research on the net so far I am still trying to find out what could be causing this.
Any suggestions would be appreciated. Thanks
So is the issue pressure or flow or temperature?
Simong - thanks for responding. From what you have said the flow of the water doesn’t change the temperature just drops. When you feel the shower pipe you can feel the temperature very quickly dropping from hot to cold and then the reverse about 5-10 seconds later. Thanks
I think the heatslave 15/19 might be a combination boiler. This could be a diverter valve problem or scale. Please confirm The one you have is a combination boiler.
Simong ok thanks will look into it further
In relation to this old post we ended up gutting the bathroom as it needed doing and replacing everything. We have put a new triton shower in and had a plumber move the pipe work from under the floor to where it is accessible. Upon using the shower we are still getting intermittent hot and cold water. This doesn’t happen on any of the taps. This leads me to believe the problem has to be with the boiler.
Are any of the other taps mixer taps, specifically ones where the hot/cold freely mix within the body as opposed to one’s where a divided flow is maintained until the end of the spout?
If all hot taps are fine and only shower doesn’t work it doesn’t seem likely that the boiler is faulty.
Either faulty/ non-existent non return valves for shower?
Or flow through shower is not enough to keep boiler firing. This could be a number of reasons......
Blocked inlet filter to shower hot
Restrictors in shower supplies ( these often have to be removed for a Combi
“Eco flo” setting on shower , remove stop in flow handle.
Restrictive hose/head .....,
Or possibly new shower is faulty.
Get plumber to look at all of above ; if it’s a bar mixer it is trivial to swap it out for another known to be working one to eliminate boiler.
Reactions: Burger
Restrictive hose/head ...,
Hi, many thanks for the above reply appreciate everyone’s time and answers. I think will arrange for a plumber to look at it. Thanks
I would agree with Ben-gee. Very unlikely to be a boiler fault.
The length/size of the pipes could have an effect on both flow and temp.
Personally, I would have advised a good electric shower. Thus ensuring hot water for washing in the event of a boiler fault (combi).
V
Bathroom Advice
Deleted member 120897
V
Bathroom Advice
