View the thread, titled "How to solder vertical joints" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Cooling it and knocking it like that will make it leak!
I didn't realise you had to use "sodder" And I've been using solder all this time!
and he used too much "sodder" as well, which he needed to do as he had melted all the flux
I could teach a drunk chimp to 'sodder' better than that in about 30 seconds. It's embarrasing how proud he sounds as well!
I think the trouble is you guys have not realised that he is doing American soft soldering, not at all like the British kind, completely different.
As we all know Americans do everything bigger and better than anyone else.
I know he was talking as he was going but once he turned his torch on, if it'd been hot enough, that should have been a 15 second operation. Way to make a meal of that!
He could have brazed that coupler with that heat!! He must go through lots of solder, I bet he wonders why he still gets leaks lol!
hahaha that is hurrendous soldering. Thanks for the video mate. Certainly made me chuckle!! haha
I just had to share the video! I also had to laugh when I saw it. I expected him to at the very least clean the joint up a bit & give it a final touch of heat. He definitely broke that joint as he give it a good battering as he prodded it.
I like how the pipe wasn't even pushed into fitting fully and then it drops in as he starts heating it lol.
2:09 incase you missed it
Yeah I spotted that. Flux must have bound the pipe in the fitting till it got hot. Powerflow flux grips pipe something awful sometimes almost to the point of not being able to assemble the joint. Never had it happen with laco,but I prefer how Powerflow makes the solder run.
I think he must have been trying to make a point or illustrate capillary action at work by feeding from the bottom, either that or hes a moron. With most of these you tube vids you would think filming was really expensive as no one seems to re shoot there vids if they poop it. If you watched that vid back surely you would think "well that was kak better do it again" have to assume he thought it was great or didnt watch it after shooting it.
He actually wiped it (more accurately, broke it) and then proudly showed it to the camera all around the joint with the solder still run down the pipe. He obviously hasn't a clue. He could have started soldering that joint in a few seconds with all that heat from his propane torch.
An occasional dab of flux on end of solder wire would help solder it better & show if solder is at melt point IMO.
People should all give a comment to his video.
Although frankly most plumbers can't solder properly
haha knew this was going to be american! Sodder , do you think if "solder" was written out for them they would still say sodder?, like what part of the L dont they get?!
Applying the solder at the back is a good sign. He did that joint perfectly. No fuss, no waving the torch about, a nice quick application of solder at the right point. Note how he made the whole video in the time the American guy took to just heat the pipe!
What do you guys use as a guide to say you've used enough sodder per joint...when you visibly see that the solder has capillary'd around the whole fitting or amount of solder? I tried using diameter of fitting as a guide for a while but found it was too much...15mm of solder for a 15mm fitting etc.
I always do vertical soldering from round the back then you can see it ring around the front
Reply to the thread, titled "How to solder vertical joints" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Best
Subscribed
Joined
Location
N.Ireland, United Kingdom
General Plumber
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
Tags Tags
None
Best,
joni os,
