ideal drill bit size for 15mm pipes
View the thread, titled "ideal drill bit size for 15mm pipes" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
F
Frank13
I am tiling a shower wall and need to drill holes for 15mm pipes that will go to a thermostatic valve, what size of drill bit for the holes is best?
16mm?! Hope you're all doing your own second fix.
There really is no excuse to tile it so tight when easy fix kit cover plates are 65mm and the talon pipe shrouds are 55mm. There's nothing worse than having to chip the tiles out because the tiler moved the pipe to fit his hole that has zero tolerance and in the incorrect spot
Also a 16mm hole won't go over a soldered cap end
No actually a cowboy builder tiled my daughters wall and left the radiator pipes hidden in the stud wall. I had to cut the board from the other side to find the pipes and drill the tiles to mount the radiator as he boxed everything in and no sign of the pipes.
Regards,
Dave
While I generally agree with your comment, I would say that having half a tile missing and a hole all around the pipe you can stick your finger through and having to patch in a new tile is also pretty bad. lol
Reply to the thread, titled "ideal drill bit size for 15mm pipes" which is posted in DIY Plumbing Advice on Plumbers Forums.
Frank13,
Ric2013,
