O
ORCHARD
Hi
Mys sons house has Ideal HE 35 fitted from new 4 years old
heating works OK but no hot water
System pressure OK at just over 1 bar
tried a reset but makes no difference
When turning the hot tap on the boiler does not fire up
The display shows an odd symbol in green on the panel which looks like this __
all the time
It would appear that the boiler functions but is not being signaled to fire up when tap opened
What trippers the signal is there a flow valve on the hot water side
The boiler technically is still under the david wilson house guarantee but the previous owner a British Gas Engineer
serviced the boiler himself but did'nt fill the service sheet in so no void
Any suggestions
Many thanks
And when you get the gsr engineer tell him its knackered and not that it just needs a service.
Nothing worse turning up for a service and finding out its goosed.
And make sure you tell him it's an ideal so that he can bring you some glossy vaillant brochures to browse through...
Reactions: 3 people
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
