bert1584
Hi all
Recently installed the Ideal logic Heat 15 boiler and am having a few problems I have not come across before.
Firstly the boiler makes a loud pulsing noise I can only really describe as whale like humming. Its definitely coming from the boiler. have triple checked F/R pipe work is correct through out the system
Bypass installed and have bled the system, there is also rads on the circuit that have no TRV, so am a little stuck on this now.
It has also been fauling on an F2 fault, which it cycles restart a few times and seemingly sorts itself out. Its installed with a vertical flue whihc is well within the installation guide limits
I'm on site everyday with it as a semi detached to US/DS conversion and every time i fire it up in the evening this is happening.
Any help is greatly appreciated!
Increase your post count to ten pm us your gsr details to start application to gsr forum
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Welcome to the forums Bert.
Unfortunately we don't discuss gas and/or the repair of boilers in open forum for the safety of people who want to have a go themselves.
I need you to increase your post count to 10+ then send a pm Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK with your gsr details.
They'll test you then give you access to the private forum where these questions can be answered safely.
Cheers mate.
