One day Rob, someone will follow some of your more interesting advice and the results will be... interesting! 😉
Reactions: Rob Foster
Yep
Reactions: townfanjon
I always follow my advice because I have learned from cohorts of old fellas who taught me many of whom are very old
all the stuff I put up by and large ...I have done
chking
yes some of my stuff is off the wall but practical binary solutions to often really simple problems....we at API.work on the principle ...
Complicated is Easy
Simple is Hard ...and guess what it works
Chking
Reactions: WC1
The frame is making access difficult so will probably need to cut the frame to get at the bitumen🙁
Have you got a long bar e.g. 20mm rebar or a 6foot weightlifting bar through the key to lever it off. Leverage is key
put a small volume of 95 Ron petrol..on it ...light a match chuck it and run away ..it you leave a straight petrol path from it then light the far end...do not use 97 or 99 Ron that is looney juice which I use in one if my cars when I want some fun
its easy ..see you at the other side
centralheatking
I love the fact that this is the second time or maybe third time in as many weeks (ish) that your solution to a problem has been "set fire to it". I actually like the way you think and also give me a chuckle every now and then. 🙂
