If that is the case why does the regulation say that the service only has to be removed after 12 months of there not being a meter in place ....are you saying it is safe for a FULL year and then it suddenly becomes unsafe !!!!!
Not safe for 12 month's and then unsafe no!
Twelve Month's is a reasonable amount of time for a dormant service to remain in place with a temporary cap. The plug cock and cap you have is, or was, more than likely still safe but it is not considered a permanent disconnection.
I think you are missing the point. They own the service pipe as I have said earlier.
They are constantly upgrading, altering and maintaining things for all sorts of reasons. There are more regulations and standards than you can shake a stick at.
Read this for example - this document should be read in conjunction with this one - decommissioning unused service pipes is something that is done for health and safety reasons.
I personally think the message not getting through to the right department is your issue. You perhaps need to concentrate on getting to the bottom of that first and foremost but I don't think you will get any joy.
If you take them to court, I expect it to cost you considerably and get you to the stage where you will still need to apply for reinstatement of service.
The two documents I posted links to are among a myriad of them. The Gas distribution network companies, do know their legal standing and duties.
Given the situation I'd personally get a quote from them for the 2 new supplies and then try and do a deal of reduced cost based on their failings over disconnecting the existing supply.
However given the attitiude and approach the O.P has exibited on this thread I think he'll be lucky to get gas into the property at all.
Thank you for taking the time to send me these documents , afterreading then nothing actually relates to my situation.
I have spoken to Gas safe Technical Department and was told that with the the ECV turned off and caped would be considered as safe for an indefinite period in fact it would be in a much safer than anyone with a meter fitted and appliances and a domestic pipeline that could get damaged or leak gas through fittings within the appliance such as gas fires, gas cookers and boilers .......stopped off was in his opinion a much safer installation as there was only the cap and if fitted correctly there is in fact nothing to fail....so i do not think safety is an issue . Thanks again for your input
you may be right lol ........but i'm no quitter 🙂
If you want to get gas supplies into your flats anytime soon then you need to be talking to Nat Grid /Cadent, not Plumbing forums, Gassafe, the Ombudsman or any other Internet source.
Trying to prove that Nat. Grid have not followed the Gas Regs, Gas Transportation regs , their own procedures and codes of practice and general H&S procedures will not get you a gas supply.
If fact I suspect it will hold of any Supply installation until your issue has been resolved.
i appreciate your concern ... fortunately the property is undergoing a complete re-refurbishment and i am still on the roof fitting the four new dormer windows so don't need gas till Christmas ......so i have time for a little battle with them for my own amusement 🙂
I have spoken to Gas safe Technical Department and was told that with the the ECV turned off and caped would be considered as safe for an indefinite period in fact it would be in a much safer than anyone with a meter fitted and appliances and a domestic pipeline that could get damaged or leak gas through fittings within the appliance such as gas fires, gas cookers and boilers ...stopped off was in his opinion a much safer installation as there was only the cap and if fitted correctly there is in fact nothing to fail....so i do not think safety is an issue . Thanks again for your input
I know it is probably safe to leave it like that. I said was that it was not a permanent disconnection.
If you ask Gas Safe whether it is better to leave a live, capped but disused service inside a property, or decommission and remove the service they will, (hopefully), tell you the latter is best.
The documents in part relate to the decommissioning and removal or replacement of underground network pipework for various reasons. Disused iron pipe work is included. Especially if within 30 Meters of an occupied property.
I am only trying to save you time and money.
I wish you luck.
I wish you luck.
i am grateful for your comments and taking time to post them its a learning curve for us all , i know you said removing would be safer than capping but wouldn't all houses be safer with it disconnected then !!!!
There is about as much safety issue's with my property as there is with the rest of the housed on the planet lol
The majority of houses with a live gas supply are occupied, so if there's a leak it would be noticed.
An empty property with a live supply, even capped is a risk, just as much from the gas service pipe outside the property as the capped ECV inside.
Hence the mention of within 30mtrs of the property.
The less empty properties with a live supply the lower the risk to everyone nearby that property.
I'm not sure you have time for any battles if you want gas for Xmas.
I think you'll be lucky to get the new service in by then.
This is what happens when gas gets loose inside properties;
gas explosions houses - Google Search
the 30m of occupied property refers to old cast iron pipework so that is irrelevant in my case............and an occupied property would be more of a risk than an unoccupied property ...... the majority of gas leaks within a property are from after the meter "not before" and the ones on the service pipe will happen irrespective of occupied or unoccupied don't you think ?
the 30m of occupied property refers to old cast iron pipework so that is irrelevant in my case...and an occupied property would be more of a risk than an unoccupied property .. the majority of gas leaks within a property are from after the meter "not before" and the ones on the service pipe will happen irrespective of occupied or unoccupied don't you think ?
P,S They cut off my supply 150mm outside my wall as it is a terrace property on the highway
Of course. We would all be safer without Gas in our buildings. That goes for Industrial, Commercial and Domestic properties. We would all be safer without 275000 Km of buried pipes carrying Gas at various pressures under our feet. That is why there is a massive industry built around the safety aspect.
The 30 Meters refers to all pipes. See below:-
23 Iron includes cast iron, spun cast iron, and ductile iron. Pipes made from steel are not covered by regulation 13A. However, steel and pipelines made from other materials still have to be maintained in good repair under the Pipelines Safety Regulations 1996, regulation 13.
This means that they are all to be included in the general maintenance programme. The removal of a redundant pipe, whatever the material, is safer than leaving it live.
A leak on an ECV could of course occur whether the building is occupied or unoccupied. The occupancy of a building does effect the risk assessment. If a building is occupied, there is more chance of someone detecting a leak and reporting it.
I think we could discuss this until the cows come home.
If you want two meters or two supplies you would need to apply anyway, even if the service was still connected. They wouldn't just install another meter without calcs. The pressure in the street may be low and the service pipe might not be large enough to supply two meters/two flats.
I think you need to apply for that to be sorted. In my area of the UK, this kind of work can take around three months from the application to it being carried out.
As I said earlier, good luck, let us know how you go on.
UK Plumbers Forums
Deleted member 120897
